both airbags were deployed due to crash, ive put two new airbags in and a second hand airbag control module, and the light is staying on.
i tried a reset tool from ebay but that is not lighting up at all, the car starts fine, roof works, everything else is ok.
is it just a case of getting the error codes removed due to the whack it had ?
thanks for any advice
SRS Hard Code
Only star Diagnostics can remove that DTC. Take it to any indie shop, pay him 125 to reset your ECU to factory parameters and it should go away unless anything else is wrong. I had the same problem.
