SRS warning light is on all the time. Any remedies out there??? Also i took my e 320 1999 to get the oil changed at your local yocal, but they coudn't get rid of the service engine warning indicator when you first start the car. Any help would be greatly aprreciated.
thanks
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Did you check the connection to the airbag in the steering wheel? There is an SRS control module under the ash tray assembly, I think, that could be bad.
