Hey
I would be most appreciative of some definitive help with, what appears to be, the common SRS warning light problem.
I have a 1994 R129 which has just been serviced. There are quite a few problems which are going to be costly to fix, so I'd like to do as many of them myself. The first is the SRS warning light
I've been googling like crazy trying to find which part number I need, and detailed instructions on how to change the sensor, but so far, haven't had much luck
I'd be grateful if someone could point me in the right direction, provide some advice, and save me a few quid in the process.
Rex
Have you detect the codes??
The switch and wiring to the beltlock is a common problem
Sent fra min H8324 via Tapatalk
1995 SL320, 1995 SL500, 1998 C280, 2004 E500 4matic
Hi. Bumping this thread as I still have the same problem. I've seen the following on eBay:
Anyone have any experience of fitting these? Wondering how easy it is to do on my R129
