2011 Mercedes E350 4matic Wagon
I had the whole malfunction deal with the battery drain. 3 weekends in a row i had to jump start the battery. Then read a a post about the seat modules. The last time i had to jump start the car, the SRS warnign came on. I unpluged the seat modules and the drain stoped. Now the SRS light comes on everytime you start the car and satys on throughout the drive.
Anyone knows where to start to look for this? I checked fuses and they seem to be fine.
Any info on this would help!
Thanks:surrender:
2002 honda civic (sold), 2009 Mercedes ML350
what connections under the seat did you disconnect? I ask because you have SRS connections under there.
2002 C230 Sport Coup and 2006 ML350
Yes, you need Star Diagnostic to reset.
Then hopefully it won't come back.
2003 C240
Same problem with my C240
After changing the battery in my car, the SRS light lit up and subsequently stayed on after that. I took it to the dealership to see what the problem was. Apparently there was nothing wrong with the SRS system, it just needed to be reseted.
C320
hi there
i had the same but it goes off sometime and sometime on !!!!!!! i have taken the car to dealer and said ur SRS senor !!!!! damage
do u think so !!!!!!??:rolleyes:
SRS light
I unplugged the CAN connection under the seat( the one that is the longest and slimmest) It seemed only to disable the seats and steering wheel and not seat heaters.
What was approximate bill to reset the SRS system?
Thank you!
P.S. The SRS light is on constantly it doesnt go off.
