SRS light on
3.1K views 5 replies 3 participants last post by  zenman 63
Hi mate someone can help please
I has change the passenger seat to double
Passenger seat in my Mercedes Vito
But the SRS light it's on.
I went to Mercedes in park royal London
But they didn't fix the problem they says I have to put my single seat back
This is stupid things but I need the double seat on my van
How can I delete the light on SRS airbag
Someone could help me please
#3 ·
Somebody has done it
Maybe I have get they information
Have a look on this post
Thanks for the help. I got a win seat from Ebay and am getting it, and head rests retrimmed in leather.
Because I want to do the job properly, the trimmers are going to swap the airbag sensor from the original seat into the twin. Yes the airbag lights come on but I have a colleague at Stephens Engineering in Edmonton, London who will turn it off for ÂŁ20.
The only issue I have is that I removed the centre consol to make additional leg room and the carpet had loads of holes in it for the mounting brackets. I have carefully cut away the centre consul and reshaped it using a bit of hardboard and grey carpet to match the vehicle (or pretty close). I have tried to attach some pics of the modified consol. I used some of the left over bits and reshaped them carefully with a low blow torch to use as a carpet strip to edge the front properly to make it look as close to what it might have looked like fresh from the factory.
I needed to use this to hide the vent tube to the rear compartment. Im guessing the cans dont have this and have carpet or mat throughout.
Will post pics of seat fitted once I get it back in leather. I will then have an 8 seater.
Not sure if anyone has an opinion to what that will add to the value (if anything) but its only cost ÂŁ60 so far for the seat and a recalled favour from a mate (about ÂŁ150) to get it recovered in leather.
Hope this is useful to some of you. I have the single seat in grey leather with the base if anyone is interested.
#4 ·
The single seat has a pad in the base cushion.
The twin has a seat belt tensioner No pad to swap over.
The yellow srs plug is also different.
Get the part number of the plug, seat half and buy that from MB with the pins.
Then fit a 3ohm resistor across the pins.
If you do this before you take the seat out the light will not come on.
If its on then MB will turn it out as long as there is resistance.
