Think I have figured it out
I removed my cluster to get it fixed not long ago
Before I removed my cluster there was no SRS light problem
I had to move the car a few meters with the cluster not installed
Bad move as I have come to the conclusion that there is a SRS test of the bulb in the cluster and if its bad it throws a fault
SRS malfunction indicator lamp (A1e15) or time limit for DTC readout /erasing 23 8.0 exceeded
So lesson learned at the cost of AU$120.00 to have Dealer clear the fault
Hope this helps anyone else avoid this
Seems a dumb idea that just because a bulb goes out its a stored fault
