1996 E320
Hello, this is my first.....
Anyway my SRS light on my instrument cluster will not turn off on 96' E320 , is that normal?
96 and 08 911 turbos
no, its not normal.
Aside from that, I can't help you. The electronics on these cars are tricky, and whenever you're talking airbags, its probably gonna be expensive.
However, you may want to check the fuses anyway, just to eliminate the obvious.
1996 E320
Thanks.
I noticed too at times the yellow middle hazard indicator in the instrument cluster also flickers but then goes away in a matter of seconds.
Does that pose a problem?
that should be your traction control, so if this occurs when you are somehow losing traction, its normal.
if it does it randomly, you may have other issues.
1997 W210 E320 Avantgarde (Japanese market)
must be a loose airbag connector from either the steering wheel or the front doors
