Just replaced my turn signal assembly which required the airbag removal. Put everything back per instructions and srs light is on. How do I clear the srs light?
Did the airbag light come on the first time you started it after replacement?
Or did it come on after your first drive?
Did you turn the ignition on while the car was apart?
To determine why it came on is the first part, if it was at first start up it could be that the ignition was turned on while it was apart, or a connector not fitted correctly, if it came on after you went for a drive you could have killed the clock spring.
You will have to scan the SRS to see what code its throwing
You will need a half decent scan tool that does SRS, there are plenty of different ones out there from about $90 into the thousands, worth grabbing one in the $150 range
