Can anybody tell me what the squeaking I'm hearing at my rear suspension? It seems like when I turn, hit a bump or go up my driveway, I can hear this loud squeak. Anybody with the same experience? Thanks for sharing in advance.
what did you replace it with?Desmodude - 1/16/2005 10:56 PM
I fixed it. Replaced the rear shocks, problem went away. Thanks Dwight.
So does your suspension still squeak?Desmodude - 1/18/2005 12:38 PM
I couldn't tell the difference yet from the old shocks. I just replaced it saturday and haven't driven it much. Not sure also if it's the updated oem. It has mercedes insigna all over it. I had help from a mechanic friend of mine. We did it in his garage. It was about a 5 hour job. It cost me $600 for the 2 rear shocks, four pair of brake pads, resurfacing of the rotors and a lunch. My brakes are squealin also so we replaced them while we're at it. The shocks and the spring came together as one piece. We just used his flat jacks for the spring tension. It was a learning experience for me especially the brake pads since MLs eats them a lot. Next time I could do them myself.
Thank you Desmodude for your responses. If you replaced all one piece (spring and shock), what did you mean by using flat jacks for the spring tension?Desmodude - 1/18/2005 12:38 PM
