1999 E 320
I live in Vancouver BC and I'm the second owner of a 1999 e 320 with 14000 KMS on it. I purchased the car 1 year ago and it spent it's life in Calgary Alberta. I've been reading horror stories about spring perches rusting and failing on a lot of these vehicals and I'm worried because my 17 year old son drives the car most of the time. The car is parked now( because I'm doing a couple of minor repairs to it) so I removed the front wheels and inspected the perches for signs of rust. The only thing I could see was the sealant seems to be intact with no signs of rust on either side but apparently the problem cannot be seen unless the sealant is removed for inspection. Should I remove the sealant and inspect them or leave them alone and inspect them annualy. If they are rusted and I replace them, where would I puchase the spring perches (I think OhLord said they don't weld them on any more they rivet them on instead) and the sealant to fix them.
1986 190E 16V Cosworth stuipdly SOLD 1999 E300 (daily driver)
Take it to the dealer.
There was a recall and free repair in Canada, I think they never expire.
You could always call first.
1997 E320, 1997 S320
just inspect them visually every 8-10 months. no need to remove the sealant, you will know right away if they are rusting.
'01-E320 & 02-ST2
There have been several reports of perches failing with no external signs. I recall reading that the proper inspection is to peel back the insulation to check for hidden rust. And of course you need to reseal it after that.
If it gives you any peace of mind, for all of the broken perches, I can't recall hearing of any that resulted in accidents or injuries.
All of that said, I agree with calling the stealer to see if they'll take a peek for free.
Good luck.
1999 E 320
Discussion Starter · #5 ·
I will run my VIN# through the dealer and see if they have been done already via recall. In the meantime does anyone know what percentage or numbers of failures or is it just inevitable that at some time all spring perches will fail on these vehicals?
My 12 years old car with 225k has no corrosion even it spend most of its life in snow belt. I've been checking the perches at each work in the area and never feel the need to peel off the mastic. All I need is 20 more years out of them.
