2000 clk320
so im looking to buy new spring pads to lower my car just a bit more, but i dont know what size to buy. so i was woundering if some one knew what the stock spring pad size is in the front and rear? also if i get number one pads all around would there be any problems with camber wear?
-george
99CLK320
there are five different thicknesses of spring pads. I am told that one can reach inside the wheel well(don't remember if it is front or back) and feel the number of bumps on top of the pad, one thru five, and that will correspond with a thickness. If you want to buy new ones for your w208 go to the dealer and tell him you want w210(the E model) pads; the part number is first and the thickness is last. each w208 may have different # pad front and rear.
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
