1 - 20 of 24 Posts
2005 SRT Crossfire
OK, I bought a gray market 73, no dash lights so I pulled the fuse panel and found this! So any bilingual owners help me out with this?
2612393
Dan
'72 450SL, 107.044-12-000422
Fuse 13.
instrumentenbeleuchtung - instrument lighting.
Check that but also the dimmer pot is a very common problem. Rotate it back and forth about 100 times (not exaggerating!) to clean the corrosion off the coil.
Is your hangar at the callaway airport?
I’m just up the road in Fayetteville.
2005 SRT Crossfire
Will pull fuse 13 and do the dimmer twist, yes hanger/home at KLGC.
2005 SRT Crossfire
OK just did the dimmer test, yes about a hundred times and got the dash lights to work! So tomorrow will pull the air cleaner to get to the heater valve and try reversing the vacuum lines. So I drove from Utah to Georgia in freezing cold without heat and dash lights, that were so easy to fix! LOL.
Good deal. Wish all the fixes were as easy.
I’ve got a 72 NA and currently delving into the DJet mysteries.
2005 SRT Crossfire
Thanks, will print this and keep it the fuse box.
Dan
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Dan
I wouldn't. The German fuse box designations do not correspond with the English fuse locations.
I'll translate them for you.
R/C107 Moderator
That would be the best way. There are differences between years and models. Even a '73 US 450SL may have a slight difference. The English translation is on the other side of the paper but it is impossible to remove without destroying.
1975 450 SLC
OH dear that is not what I wanted to hear as I don't have one for my Aussie delivered 75 450SLC, I will have to do some more research.
O.K.
Anything (........) means option.
Fuses: triangle = 5 A Yellow, rectangle = 8 A White, white circle = 16 A Red, solid circle = 25 A Blue.
German fuse box
# 1 Hazard lights
# 2 Clock, trunk & glove box lights. Einstiegsleuchten = car entry lights or door lights (power antenna)
# 3 (Power window front right & rear left) (Sunroof)
# 4 (Power window front left & rear right)
# 5 Window wipers, window washer pump, high beam flasher, signal horns, zig lighter
# 6 (Radio)
# 7 3-way valve heating, (A/C magnetic clutch), blower fan
# 8 Zusatzlüfter = aux fan / additional fan
# 9 (Rear fog light) (France/Italy)
#10 Brake light, relay for start valve Kl.30 (automatic gearbox)
#11 (Heated rear window)
#12 Rev counter - tachometer, blinker (=turn signal) & reverse light combination instrument
#13 Parking lights, license plate illumination, gear light - i assume is the gear indicator light @ auto shifter, instrument cluster light, lighted hazard switch
#14 Electronic main relay Kl.86, fuel pump relay Kl.30
#15 (headlight washers) , fog light, fog tail light
#16 Standing light left, taillight left, parking light left
#17 High beam, high beam control
#18 High beam left
#19 Low beam right
#20 Low beam left
P.S Some German tech descriptions can be a bit ambiguous. One of the best tech translation sites imo is leo.org of the Technical University Munich. Otherwise, shoot me a message.
2005 SRT Crossfire
Discussion Starter #17
Great, I will copy this and keep it in the fuse box, with a fine point pen I think I can use the original.
Dan
I posted a link to this discussion along with pic of fuse card in the Fuse Chart Compendium.
BTW: That thread, like a lot of others got screwed up by the BW platform change. But most of info is still there.
R/C107 Moderator
That's being kind. Contrary to their statement and promises that the broken links have been fixed they still haven't. And our Admins are still out in the cold AFAIK.
R107 300 SL, Year 1986 and C124 300CE-24 Year 1990
Hi,
on the reverse side of this fusechartpaper, there is the fuse chart in english!! Carefully loosen it.
1 - 20 of 24 Posts
