1 - 8 of 8 Posts
Mercedes Benz
I have a 240 D Mercedes 1982, I wanted to put 20in spinners on it. They also have 18in so i can adjust to the smaller size but i'd much rather have the larger rims, they cost the same basically, and what width do i need, and what size tires would i have to get? thanks.
BenzWorld Tire & Wheel God
you would need a 7.5" wheel and I do not believe you can make a 20 work on your car becaus...
you would need a 7.5" wheel and I do not believe you can make a 20 work on your car because you need a tire witha 25" diameter
Mercedes Benz
Re: you would need a 7.5
do you mean if i had 20" wheels that i would need to have 5 more inches of tire in order for it to fit in the wheel well? is that from ground up, or just from the rim? what about 19", 18"...
this picture desribes what I stated in the previous post
[img]https://www.tirerack.co...
2009 CLS
OK! A 21 yr old car that costs as much as a 19inch tire and u want to put some "Spinning"...
OK! A 21 yr old car that costs as much as a 19inch tire and u want to put some "Spinning" rims on it? What is the matter with u? Do u even have a license? Turn the BET and MTV off and pull ur pants up
96 E320
Dont listen to him i think it would look great, i have a friend with an older benz and he ...
Dont listen to him i think it would look great, i have a friend with an older benz and he added 18'AMG and spacers and his car looks better than some stock newer benzes out there.... go for it!!
96 E320
just took a look at the car your talking about in your profile,,, i take back my last me...
just took a look at the car your talking about in your profile,,, i take back my last message.....lol dont put rims on that! id rather re-invest in a Yugo.
1 - 8 of 8 Posts
