61 - 64 of 64 Posts
I'll check that out when I get home, currently at customer office.
W210 '97 e300td / W210 '97 E280 V
Discussion Starter #62 (Edited)
Hello, did you check? Will the engine with these errors work normally ???
(will code a manual gearbox)
Alternatively, if necessary, and an abs signal is needed, can I only install the abs controller and connect the sensor one or many ?? without abs pump,
I have an abs sensor with a ring. i will mount it at the output of the reducer (the number of teeth is already calculated to match the shaft rotation relative to the wheel rotation originally.
Link does not work anymore. But check for vacuum leaks, those will cause delayed throttle.
Did you also check the injector o rings? Spray water on it with water bottle and watch the misfire data on scanner.
1998 E320 base sedan @ 160kmiles
Do you have a good scanner to monitor fuel trims, MAF, open/ closed loop status ? I believe your engine controller stays in open loop (no air/fuel supervision and control).
61 - 64 of 64 Posts
