I understand, but sometimes it isn't:
If the motor sees it is in P / N position, it is okay because if the motor was in D position the motor would not have the wheel speed signal and would cut off the power? - mode failure?
P1570 / P1603 - i think this is a problem because i have an immobilizer emulator, the engine starts without problem every time, problem with the CAN is because the engine does not see any signal ??? no gearbox, no comfort module, no abs, nothing ?
P1605 / P0500 / P0600 - this is a problem because I do not have a gearbox module and I do not have an abs module
P1747 - no instrument cluster connected
P1179 / P1178 / P1177 - oil sensor but the computer show: oil level OK, oil temp 215*C,
I want the engine to work normally,
I have other devices to show oil pressure, oil temperature, engine temperature, RPM, manual gearbox,
in my other car, when something is bad, then I have a failure mode, the car has no power, max 2000 rpm, and speed 60 km / h,
takes a lot of fuel.
This M112 engine will it work normally with these errors?
The power is, the maximum speed was 170 km / h yesterday,
only the fuel consumption is terrible
