Hi everyone. I took out my instrument cluster, cleaned out oil underneath the oil pressure gauge, put the unit back together, and reinstalled it. All the gauges work now -- even the tach works sometimes (I think I've isolated its unreliability to a loose plug behind the tach). However, I do have one problem now.
I read the service manual page about the inst. cluster, and it told me I needed to release a clip holding the speedo cable under the steering wheel behind the brake pedal, which I did, and got lots of slack to replace the speedo cable. The speedo works, but now, above 25mph or so, I hear a loud bearing sound coming out of the speedo that varies directly with the speed. Here's a link to a video I made, in which you can sort of hear it:
300SD speedometer cable noise on Vimeo
It's strange, because I didn't take the speedo apart at all, and I was never rough with it. Any ideas would be appreciated.
Thanks!
Thanks!
