1988 420SEL, for sale
I've read all the posts I could find on speedometer bench testing, but still not quite sure if I have all the information. I replaced the odometer gears and capacitors a while back to fix that issue, and it worked okay for a while, so now I think there is a bad trace somewhere, as I could tap the dash to revive it each time it quit, but that stopped working. That old PCB was hard to solder without damaging the foil. Is there a schematic for the speedometer section? And does the square wave for testing get applied to the big pin or to the middle pin on the 6-pin connector, between the +12v and GND pins? I have a function generator to drive it on the bench. Thank you for your help!
93 190E 2.6; 82 300 SD Turbo
Steve,
I usually test them by sending signal into the 6-pin connector. The bottom row is labeled. 31, G+, 15.
31= ground
G+ = square wave 12Vpp.
15= 12V.
Here's a video, of a 350SD speedo under test:
You may need to play with the duty cycle and frequency of your function generator to get it to swing full range.
