G
i just installed a sub in my clk430, and it is tapping into one of the rear stock subs behind the back seats, but the speed sensitive volume control is making it impossible to adjust the gain to the correct level. at stop, the car sounds great, but then on the freeway, there is way too much bass. does anyone know if you can access the bose amps and if it is easy to turn off the speeed sensitive feature? i know the dealer can do it for u, but is it an easy fix i can do myself? thanks
2001 CLK55 AMG
Speed sensitive volume
Im curious about this as well, one less trip to the dealer for something that can be simple would be great
CLK55/G500/E55/ML55/etc.
I believe the speed sensitive volume in your car is in the head unit, not in the amplifier...
I believe the speed sensitive volume in your car is in the head unit, not in the amplifier. So, cut pin A1 going to the radio.
-s-
Depending on your head unit, this may be programmable (but it might not be).
Let us k...
Let us know how it goes!
-s-
00 S500,99 4wgn,87TD
Re: I believe the speed sensitive volume in your car is in the head unit, not in the ampli
-s-
or was it the red wire........
Re: Re: I believe the speed sensitive volume in your car is in the head unit, not in the a
-s-
It's usually green... but may vary.
-s-
