'91 420SEL '80 300TD
While driving at about 65 mph, I set the speed control. Traffic pattern changed and I pushed the lever down to lower the set speed, then changed my mind and pushed it up. Suddenly the car slowed down and did not respond when I pushed down on the pedal. It seemed like it was stuck in 3rd or 4th gear and had no acceleration.
I assumed I had screwed up the computer or sensors, so I drove off the highway, stopped and turned off the ignition. Restarting the car, it resumed its normal pattern and responsiveness. So I guess the rapid up and down caused the speed control to malfunction.
Anyone had similar problems? What happened?
1991 300SE
Wow. That's a new one on me. It could have been a "confusing" input when you shifted the lever down, then up so quickly. I have not had that problem with my car, ever. Maybe checking your electrical connections on the cruise computer wouldn't hurt.
Moderator
1991 500SEC 55K mi. 1987 560SEC Now 153K mi. 2020
Hi,
Your speed/cruise control won't affect what gear the transmission is in generally speaking. I suppose if you were to RESUME speed from a much lower speed a downshift might be in order.... but that condition is quite different than what you describe..
By shutting off the engine & restarting you reset the cruise amplifier/ control unit. That is where I'd start.
Cheers, MBL
