1 - 18 of 18 Posts
ML 430
Hello,
Review a lot of post from u folks.
Have a 99 ML430 with BOSE system.
And I'm looking for upgrade my all speaker recenely.
-That what I'm looking for-
MB Quart DSD213 5.25" for rear door and
MB Quart DSD216 6.5" for the front door.
I'm wondering if the Bose Amp take those speaker(s)?
Been hear lots of discuss about the 2ohm/4ohm
Will the AMP end up stop working after I install
the new speakers?
Thanks,Phil
ML430
To get the sound quality you want out of those speakers, i would suggest to remove the Bose AMP and put a aftermarket amp to those speakers. Maybe a 400/4 JL.
ML 430
Thank you ttaleric for the info.
Does anyone know how to pull the BOSE AMP out a 99ML430?
Any advice would be helped!
I know it's behind the dash. In order to get the amp out, should I pull the dash out? or there is some other way to make the access to the Amp.
Thanks,Phil
2014 ML350 BlueTec
Help me out..l thought the Bose amp was under the driver's seat....it was in my 1999 ML 430..take a peak....[:D]
ML 430
RE: AMP Location
According to my research, the one under driver seat
is the BOSE sub-woifer.
The Amp is behind the Desh, but I would need u folks that expenienced on mod their ML's AMPs...
Thanks,Phil
98 ML 320
philchen1979 is correct, the bose subwoofer is under the driver side seat and the amp is behind the dash.
98 ML 320
ML 430
sage3 - 5/2/2005 1:24 AM
Thank you just call me Phil is fine.
Do you have any information on how to remove BOSE AMP? Photos or text would help!
thanks,Phil[:)]
ML 430
Was also wondering, If I have my speaker upgraded,
Does it matter with the AMP upgrade?
I know if I change AMP the sound will be more improve, but what if I don't change the AMP, just keep BOSE AMP.
All reply helps!!Thanks,Phil[;)]
Mercedes "M32"
philchen1979 - 5/1/2005 5:03 AM
It will only sound as good as its weakest link ... if you upgarde the speakers you will be limited to poor quality sound bec of your stock amp. I suggest you get a new amp and head unit when you get the speakers. It will make things a whole lot simpler and it will sound right.
ML 430
Discussion Starter #11
MLOffRoad - 5/3/2005 8:04 AM
Thank you ML OffRoad,
Do u have BOSE package as well?
or Did you add the aftermarket AMP w/speakers.
Thanks,Phil
Mercedes "M32"
No problem ... and yes I have the BOSE system but havnt upgraded yet to the system I want. I'm still saving up since it will cost me about $4-5K for everything I'm going to get.
ML 430
Discussion Starter #13
I think you must have a pretty wide range of $$ to spend! That is nice I think I will limit my budget to under 1k =) still hoping DIY!!
ML430
I have yet to find where it is. But this summer I am planning on finding it. I will take a stab at it though. I think it is near the passenger foot well. Somewhere up there.
I know this does not help, but it just might point you in the right direction. If worse comes to worse just run new speaker wire. I am running my stock speakers with my system, and it sounds decent.
Let me know if you find it. Being exam week I have no time to rip apart my dash and help ya look. Good luck!
98ML320
I think this is the information your looking for
http://www.keysolutions.com/M-Class.nsf/8178b1c14b1e9b6b8525624f0062fe9f/ad96201628ab6ea685256921000856f8
ML430
So, after much foraging, under the dash, on the driver's side, way up in the corner (follow a line from the cup holder straight back towards the firewall) is a Bose combo line-output-converter/amp/equalizer. So this little puppy takes the speaker level output form the head-end, applies an equalization curve to it, and then pumps this out to the four speakers plus the "sub-woofer". The main implication of this is no matter what head-end you use, it will not sound much if any different.
Well.... I was way off!! hahah
1 - 18 of 18 Posts
