Hey everyone ive got a 1988 260e and was wondering if anyone had any ideas to why my 2 left side speakers arent working the 2 on the right side sound find but there not busted because i hooked up 1 speaker from each one into my trunk and the left one does nothing but the right is fine i just switched alot of my old fuses out to so any advice will be great
ML430
First I would pop off the door (if you have to) attach a speaker that you know works and try to play from it. If it works then you have a blown speaker. If there is nothing coming out of the speaker then either the wiring is bad, or the deck is bad.
Good luck!
98 SL500 SPORT SLVR
If its both the left speakers going in and out then its not the speakers. Its your radio's or amp's left channel going bad. Go aftermarket and wash your troubles away!!!
