1 - 20 of 50 Posts
1987 Mercedes Benz 300E
hi,
what is the exact spark plug part number for an 87 300E??
thanks guys:)
thanks so much, ill look into it right away.
by the way, are they resistor or non-resistor plugs??
W124 Moderator
Both options are pure copper NON-resistor plugs that meet OEM specs. I purchase Denso's on Amazon NGK's from clubplug
Jayare
99 SLK230 Kompressor, 5 Speed Manual
I've had very good luck in these engines with various premium copper core plugs. I tend to buy the Bosch, but even Champions work quite well. What you do NOT want to do is use a platinum plug. The center electrode is very thin and occasionally breaks off causing engine damage.
Also, remember that this is an aluminum head engine. Use a VERY THIN coat of copper based anti sieze compound on the THREADS ONLY! Do not let any be exposed to the engine internals.
`86 300e 5spd
Bosch F8DC4's will work they're OE cu non-res. for m104
if you're adventurous I found some racing plugs at summitracing.com that match the specs of the OE H9DC's that go in the m103.
5/8" hex
14mm thread
.708" reach
copper core
non-resistor
Autolite
AR472, 473, & 474 just different heat ranges 7-9 i think the R is for racing not resistor
NGK
1049, 1085, 3526, 7317, 7841, 7993 varying heat ranges as well
none are more than 3$ a plug. I just ordered a set of F8DC4's from amazon,
but i may go ahead order a set of NGK's from there to see how they do. A little more research may be in order though .
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
I installed a set of NGK BP5EFS plugs (new #3712) in one of my M103s back in August. The engine has about 215k on it. So far, so good.
I got them through Rockauto and they were shipped from their UK warehouse via FedEx Intl. Shipping wasn't cheap so I bought 18 plugs at the same time.
1992 300ce, 3.0, 207,00 mi.
Nice pic of a non-gasket taper seaty plug. Don't use an F8DC4 in your 103 motor. It won't seal properly and will not reach fully into into the comb chamber.
Dealers now have the Beru and NGK's in the supply chain... at least that's what it looked like to me when I got plugs last month.
1987 300e (W124) - 223K miles, 1995 C280 (W202) - 250K miles Sold
1990 W124 300E Base
Wrong plugs for that ignition system, but it goes with the wrong ATF you use.
These are the correct copper core, non resistor plugs I sell, F8DC4
Made in Germany, not Russia like aftermarket Bosch yellow box
Do you sell them through a website or do we PM you for details?
2000 E320 (W210) Obsidian Black
Spark Plugs - the right ones.
A lot of questions I read on this site can be answered by referring to, of all things, the Owner's Manual. I looked in mine and saw on Page 119 the specs for spark plugs (4 x Beru(?), 2 x Bosch and 1 x Champion).
1 - 20 of 50 Posts
