1) mercedes recommended bosch F9DC0 for my car
2) i found here
Bosch to NGK cross reference
that replacement for this spark plug is one by NGK; BCP4ES
3) However if i visit NGK web site I can find that they recommend BCP6ES 8some sites recommend also BCP5ES) which is less hot spark plug.
What to do?
Another dilemma is: Bosch replaced their F9DC0 with FR8DC+. I had these in my car in last 20.000 km. How is this possible? How can a spark plug with resistor replace one without it? I spoke with Bosch representative here and he said that resisitor in this spark plug is 6,000 ohm. the spark plug boot on my car has 2,000 ohm inside. What is going on? can someone explain this? maybe additional resistor is not a problem at all but i assume that 2k ohm in spark plug boot is the only resistance which was predicted by car designer.
now i have NGK; BCP6ES in and idle is still shaky. I assume even if temperature value of this spark plug is not optimal, the idle should be ok for coolant temperature 80°C for brand new spark plugs. is this right?
thanks.
2) i found here
What to do?
thanks.
