1 - 13 of 13 Posts
1986 560 SL
I have searched the MB CD manual in vain. Can someone tell me the recommended gap for a '86 560? Thx.
1988 560SL
According to Bosch USA the gap for standard plugs and the super replacement is .032"
"W9DC0 OEPLUG GAP=0.032"; When stock is depleted, please order the recommended Super Spark Plug."
2017 Police Interceptor Utility, 2017 Police Interceptor Sedan
You could always search the large label on the radiator panel. That search won't be in vain.
1986 560 SL
Thanks Ike. I just had a look underhood. The rad support has 3 labels pertaining to emissions control and freon, and a metal vehicle ID tag. The rad itself, which is a Behr replacement, has a couple stickers about itself. Nowhere do I see anything about plug gap....
The last time I bought Bosch plugs, the gap was printed on the box it came in.
.032 or .8 mm
Is the gap preset?
I was told that if the packaging wasn't damaged the gap was proper. Any other comments.
Good question dugald.
BenzToy said:
Is the gap preset?
Yes it is preset but I personally always double check.
I also seem to remember seeing it in the owner's manual.
1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean, 2013 F10 BMW
Spark plugs are pre-gapped at manufacturing but can be off from transit. Always check the gap prior to installation.
If you want to feel a smoother motor, gap the plugs to .042, this gives the car smoother response.
Regards,
1986 560 SL
I bought a set of Bosch Superplus plugs today at AutoZone for $1.99 per. (If you are feeling rich, you can buy plugs at $9.99 per, which I think is a bit much for a consumable item....)
Their database confirmed the recommended gap as .032". The counterman cautioned me not to trust that they were gapped properly ex-factory.
As it happens, they all came out of the box at .030. I gapped them at .035 as a timid compromise between the recommended .032 and the said-to-run-smoother .042.
I haven't installed them yet.
You mean the emissions label doesn't go into the whole engine family 117 yada-yada, catalyst yada-yada, spark plug gap yada-yada?
1986 560 SL
Discussion Starter #11
Nope, no mention of plug gap.
1 - 13 of 13 Posts
