Spark Plugs
Every 100,000 miles. I would use only OEM plugs.
You write that there's not a compatible synthetic fluid... well...oldnews - 9/30/2004 11:25 PM
The other thing is the transaxle oil. Do it at the same time using full synthetic oil. There's not a compatible synthetic transmission fluid, only dextron III.
Good luck.
Read your quote... from AllData, it states... Model 722.6 uses ONLY MB Automatic Transmission Fluid. The CLK has ALWAYS had a 722.6 transmission in the USA.oldnews - 10/1/2004 10:15 PM
From alldata - if you know of a compatible synthetic fluid for an american spec transmission, what is it? Brand name and description please.
AUTOMATIC TRANSMISSION FLUID
For MB automatic transmission (not including MB automatic transmission W5A580, model 722.6), transfer case (4MATIC), and MB manual transmission (except GL76/30-5 and GL275E) use:
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257 / 22096
Chevron ATF Dexron III F-30108 / 30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron-III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Pennzoil, ATF D-21380
Pennzoil, ATF F-30110
Quaker State Dexron-III/Mercon F-30161
Sunoco ATF Dexron-III/Mercon F-30176
Texaco ATF Mercon/Dexron-III F-30321
Unocal Multi-Purpose ATF D-22413 / 22431
Valvoline ATF Type D
Supplier Information:
Castrol, Piscataway, NJ / Toronto, Canada
Chevron Products Co., San Francisco CA
Citgo Petroleum Corp., Tulsa, OK
Exxon Company USA, Houston, TX
Texaco Lubricants Co., Houston, TX
Pennzoil Products Co., Houston, TX
Quaker State, Seneca, PA
Sun Co., Philadelphia, PA
Unocal Science and Technology Div., Brea, CA
Valvoline International, Lexington, KY
For MB automatic transmission W5A580, model 722.6 and Model 163 transfer case use:
MB part no. 001 989 21 03 10
It's hard copy, hard to post... you can get it from your MB dealer too.oldnews - 10/3/2004 8:18 AM
Please post it if you've got it.
