C-280
I changed my spark plugs in 99 C280 with 123,000 miles. I have lost about 60 miles per tank of gas. Anyone else see this in there car?
2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Your saying you lost 60 miles AFTER you changed out your Spark Plugs? :confused:
or
You lost 60 miles per tank and then decided to change out your Spark Plugs?
If you are down 60 miles AFTER the change:
What sort of plugs? - correct gap?
You might have initiated a coil/harness problem when changing one of them? - how is it running?
Maybe it's running so well now that you've been a bit enthusiastic on the gas pedal?
Oberoi
W201, W202, W203, W204, W205 Moderator
Amethyst 2001 C320
Did you use single, double, or quad tip plugs? That can make a difference too.
C-280
Ive lost the gas mileage after the change, it runs fine and smooth. Relplaced with quad tip, no gap necessary plugs. Second tank of gas and its getting better.
