Hi, i'm currently converting my 639 into a camper, is it possible to move the spare under neath the van rather than above the rear wheel arch as its takin up a lot of room and dont look to good there either.
cheers
Neil
ML63 AMG & 2 350 SLK with AMG kit.
When you get the tyre off, white fluid runs out, messy stuff but it's not hard foam, what kill's the tyre is running it flat and the rim eats the side wall, thats what the compressor is for.
There is not offen a tyre that can be repaired safely anyway, it's just to get you out of trouble.
Yes m8 i know wot your sayin its a good idea but if i had a blow out then tyre weld wont sort that so i think i'll just av to put up with the spare in the back.
thanks for the info anyway.
cheers,
Neil.
