1 - 10 of 10 Posts
1986 Unimog U1300L
Hi,
my spare wheel is going to live on the tray.
Who has the spare on the tray too? How do you get it on and off the tray? Anyone mounted a spare vertical on the tray?
Looking for practical ideas.... got lost on google...
Cheers
Andre
'78 Mog 416.141 DoKa
I have mine ratchet strapped on the deck/tray. Right now, if needed, it would be muscled down to the ground. Eventually, I'm going to build a hard mounting point using tubing and a spare hub I picked up somewhere. This will be a little less worry then maybe having a ratchet strap break or come loose.
It's a heavy lift, for sure, but I also like the idea of that weight waaaay back there to help a litle with the nose heavy stance of a 416
1986 Unimog U1300L
do you know any brands or better keywords than "crane" to google for?
1991 1250L Doka Unimog, 2002 ML320
I started out with a hydraulic cheapie from Harbor Freight and then bought a used Autocrane from Von. Positioned as it is I also used it to swing around and raise my cab. I have it fully customized (dents) from the Rubicon and now the first part of the trail is clearanced for square-cabs....
1 - 10 of 10 Posts
