CLK430
Can someone verify that I am doing this right?!?! If I want to put a set of rims........19x8.5 front and 19x9.0 rear on a 2000 clk430 with a 38mm offset, then I should need a 1mm spacer for the front and an 8mm spacer for the rear.........correct? I guess I'm going to need new bolts too..........where do you buy them?
2001 CLK 43Cabriolet
I am not sure if you are looking for wheel spacers, or hub-centric rings. If you are tlaking about the rings, here is what I found out today:
I was stoked to get my wheels delivered today, but I ram into a snag while getting them mounted. The tire shop sent me the wrong ring size rings; and I have to wait until the correct one arrive. [:(!]
You will need two measurements to get the right hub ring, the interior diameter and the outer diameter.
Here is the info I have gathered so far, I hope it is right.
66.1mm - 73.1 mm
I am assuming the 66.1mm wull fit any W208, you will need to get the other measuremnt from the wheel mfgr.
If this info is not correct, someone in the know set me straight.
