1997 S600 - Bentley Turbo R (black/black)
i have 97 s500...and the sound in one of the speakers comes and goes when i go over a bump....if i go over a bump the sound will dissappear, then once i go over another bump then it will come back on...and so forth..
can anyone tell me what is the cause of that?
thank you
ghost
'82 380SL+'02 ML320
Speaker sound loss
No audio expert, but sounds like a loose wire. Unfortunately, if the S is like some of the others, you have to remove the door panel to check. I watched them remove mine on a '94, and too much risk of breaking pins for me to do.
A reputable sound shop might check it for you for a couple of bucks if you were willing to replace a bad one with a pair from them. If you have Bose, unless you replace bad speakers with exact replacement, you will change the sound space in the vehicle, so they say. Good luck.
