2005 SLK 350 Sport
Well tonight I pulled most of the trunk out and installed sound deadener. I bought Fatman but when it came today I opened the box and was hit with the smell of asphalt. They said it had no odor but that wasn't the case. So I am going to send that back. I found 1/8" thick adheisive foam at Home Depot and installed that instead. 15 Sq feet was $17.70 it took a little over one roll to do the trunk and about 3 hours. I was going to pull the side panels but there is 1/2" padding behind there so I didn't see the need. Man what a night and day difference in quietness. I could really hear a difference on my way home this evening. Alot quieter.
2007 SLK350 Sport
Sound Deadener
Sweet SLK, that is an interesting to Dynamat which several of us have installed. Your solution is much cheaper. I have been very satisfied with Dynamat. Have you considered putting in the openings of the trunk lid, then covering it with black carpet.
2001 SLK 320 Sport
Is duct insulation a good sound deadener? I mean you can't beat the price at 20 dollars for the entire trunk, but how much quieter would Dynamat have been?
Also, how sticky is this stuff? I know that Dynamat is a mess to get off once installed/stuck, but I bet this material is a bit easier to work with. Either way, pictures looks great and it's something I am definitely considering.
2005 SLK 350 Sport
Discussion Starter · #6 ·
I might do the trunk lid but I haven't decided yet. Made a big difference in sound. The foam deadener I used is open cell. I've never had a water problem in the trunk. This foam is no different then in the interior under the carpet. I had a leak and the foam under the carpet was like a giant sponge. As long as you don't have a water problem in the trunk I would think you would be fine. On Sunday I replaced the stock amp and woofers. I will post pictures of that tonight.
