2000 ML320 / 1988 300SE / 1985 380SE / 1969 280SE
As soon as the engine is turned on, there is noise coming from the underneath of the car and it sounds like hitting something.
I was suspecting loose exhaust pipes but there wasn't any movement along the pipes or near the muffler.
The transmission mount was recently replaced.
Anyway, I am taking it to my mechanic for inspection tomorrow and interested in what he will find.
Has anyone experienced this kind of problem?
01 e320 4matic wagon
I know I have this problem sometime when hwy cruising and I believe it to be the heat shield/alum blanket that is flapping around. Might be worth to check that out while you're under there as well...just a thought
'01-E320 & 02-ST2
Hard to go on with that limited description, but if it's a lighter sound, like a rattling, that is likely the cats. Common issue. Hopefully they have some affordable aftermarket units over there.
Bingo. It was the cats.
There was tapping sound (or rattling). I first suspected the heat shield with loose bolts.
The mileage on my car is 188,000km.
I asked my mechanic how the cats can fail even before 200,000km and he said it could happen even before 100,000km.
If this is a common issue, does my cats failure sound reasonable at this mileage?
My 380se(1985 model) hasn't not shown this issue yet even after 200,000km.
Thanks for your input
I paid AUD400 including labour
For aftermarket cats. USD400(=AUD400).
