1986 560SL
So, after replacing chain, guides, tensioner and oilers and describing in another thread the leaking driver's side valve cover I go back in and meticulously take everything off, clean and replace gasket and cover. Success! Or so I thought. When I went to start it the car idled badly and ran even worse. Drove it around the block thinking it would work its way out. Started smelling burning plastic and when I opened the hood smoke billowed out. What now? I went over everything I touched and noticed that as careful as I was somehow two of the plug wires got reversed. Fixed that and the car runs as it should. Question. What the heck could have been burning and am I lucky to have shut the motor off in time or do I have a ticking time bomb here? Somewhere in another thread I read about the EZL-could that be the part in question? The burning seemed to come from below the driver's manifold. Or could I have somehow just dropped a piece of plastic on the manifold (have no clue what) and it started melting?
Bob
1988 560 SL
No matter how careful I am, whenever I've pulled a valve cover from the 560, some oil always finds its was to places that get hot upon re-start. The smoke from the burning oil would make you think that there was a damn fire, but it only lasts for a few minutes. Shortly after, all is normal again. At least that's been my experience.
John
1986 560SL
It definitely smelled of plastic-no doubt about it. I had sprayed the mainfold with degreaser to clean up the oil that inevitably drips down as you pop the cover so there was very little of that residue.
1986 560 SL
The EZL is tucked under the fender near the driver's side headlight.
And if it was burning you wouldn't likely be running.
