ML 430
I just go a 10" sub woofer installed in my ML with a amp. I started noticing "popping" weird noises coimg from the sub woofer, i comes and goes. The weird thing is that when ever I move the Audio inputs on the amp, it makes popping sound. Is that normal?
Shouldn't it not make any noise? Not sure, but I suspect it could be the ground wire or something that's doing this.
Any help will be appriciated, thanks!
andaya
CLK 430
That happend to me twice, once the amp came loose and the box split one of the wires most of the way through, second time was a loose wire. All in all blew out all my fuses (the extra protection ones that were installed when I got the system)
