Of course those days, I just had to drive and/or get it stuck.
Unfortunately, the Safari Top is just a single layer, fiberglass cap that provides no thermal advantage other than fiberglass vs metal. The raised height does, however, provide a good amount of room for added insulation or soundproofing.I believe that's the "safari top". Double shell design allows for a void space and voila thermal insulation layer.
Bryan, I don't think that you can dump out the back with that bed, it will hit the frame. I have the same long frame on the new hotrod truck I am building for myself. (look on my website under "Current Projects") In order for it to dump out the rear, I am stretching the spyder frame and moving the rear mounting post on the bed back to match the spyder frame. The dump cyl. will now be on the other side of the "X" in the spyder frame, but you can mount it on either side. Hope to rebuild my bed and do this work soon, and I will post it on my website.Hi Von,
Yes, it's a 3 way (I ALWAYS wanted a 3 way, but back to the mog) tipper. I don't have a cylinder for it or hydraulics - that's 3 major projects away!
Bryan
Von, I ran into the same debacle when mounting the spider frame on my 416, and I seem to recall that docfranco here had a similar bed, with weird pivots and questions. On my 416 there were 2 positions to mount the spider frame. The forward most was as itjobhunter pictured and would only allow the bed to tip to the side because of the long overhang. I chose the rear most position, and extended the front spider frame pivots towards the cab, and built my bed to fit. If you could move the spider frame to the rear, might it not be easier to just cut the pivot sockets from the bed and remount them as needed?Bryan, I don't think that you can dump out the back with that bed, it will hit the frame. I have the same long frame on the new hotrod truck I am building for myself. (look on my website under "Current Projects") In order for it to dump out the rear, I am stretching the spyder frame and moving the rear mounting post on the bed back to match the spyder frame. The dump cyl. will now be on the other side of the "X" in the spyder frame, but you can mount it on either side. Hope to rebuild my bed and do this work soon, and I will post it on my website.
Seth,Von, I ran into the same debacle when mounting the spider frame on my 416, and I seem to recall that docfranco here had a similar bed, with weird pivots and questions. On my 416 there were 2 positions to mount the spider frame. The forward most was as itjobhunter pictured and would only allow the bed to tip to the side because of the long overhang. I chose the rear most position, and extended the front spider frame pivots towards the cab, and built my bed to fit. If you could move the spider frame to the rear, might it not be easier to just cut the pivot sockets from the bed and remount them as needed?
