07 E63 + 07 CLK63 Cab
Can anyone tell me if the hex shaft on the front of the compressor should turn the AC compressor and if it does not turn this I take it would mean the AC comp is siezed. This is on a 2007 E63 which had shown no prior indications other than after sitting for 6 weeks blows hot air only. Freon level was drained vac tested then refilled to proper levels, no issues found. Car runs well no issues with serpentine belt, main fan will turn on wide open when pressure switch plug is removed, shuts down when reconnected. Just cannot understand why all of a sudden no AC, worked well on this vehicle before parking in garage??
:bowdown: Thanks in advance for any ideas.
Discussion Starter #2
Are there not any mechanical thoughts about my AC issue
2 days and no one has any idea or expressions to help???
Question, if 7mm hex shaft will not turn does this mean the compressor is siezed.
Thank you in advance.
