1 - 10 of 10 Posts
73 450SL
My soft top, when you try to close it, the latches that connect the front part of the soft top to the top of the windshield do not quite reach far enough to fit into the holes.
I've seen videos on youtube where people have recorded howto videos on how to operate the soft top, and in all those videos, the top just lands right on top of the holes. For me, I have to pull really hard to get the top attached.
I think the fabric was replaced and the new material just hasn't stretched out yet. Is this a common thing?
My hard top, when you try to close it, the latches that connect the front part of the soft top to the top of the windshield do not quite reach far enough to fit into the holes.
Depends on the fabric. Vinyl is much more prone to change with temperature. Are you leaving the back "unclicked and untightened" while you attach the front?
82 380SL. Past: 75 450SL, 59 TR3A, 64 TR4, 66 250SL, 69 280SE, 75 450Sl, 79 450SEL
I put the pegs in the holes and then rotate the pegs half-way down, then click the back end, then complete rotating the pegs with the handles until close, then lift the handle drawing the back end down. My very old 380SL soft top is a lot harder to close than my brand new 450SL soft top. I think the fabric may shrink over many years especially where it is very hot.
If it's vinyl, wash it with hot water and that will allow quite a lot of stretch. The old TR's, Healeys, MGA's used to have vinyl that was a bugger to put up when cold. If it's cotton duck fabric it may be bad bar fitting but they are not normally adjustable. I don't know if you can move the frame at the base. Good luck.
· Always Remembered RIP
1979 280sl 4 sp w/ac 1957 MGA 1998 volvo xc/70 2004 F150
Soak the inside with a spray bottle and leave the top up for 2 weeks spraying every few days. This will relax the fibers and let them stretch.
· Outstanding Contributor , Bob's Your Uncle!
83 280 SL- 5 speed-The PIG
Maybe I'm splitting hairs here....but are you talking hard top or soft top?
1 - 10 of 10 Posts
