Hello all. My drivers side door only no longer soft closes all other door and trunk work properly.
If the air pump runs for more than the needed time to pressurize a line whether it was a door or a seat it will de-activate that line in order to protect the pump untill you fix that line. this happened to my driver's door lock; the pump kept on running for all the other doors and when I replaced the soft closing lock in the driver's door everything went back to its normal position:thumbsup:Hi all. I've been a long time member but this is probably my first post. Anyway, I recently developed a problem with my 2001 W220 passenger door. I followed the suggestions for the rear seat fuse reset only to find out that I have an air leak. I was better off not resetting it, but, at least now I know what's the problem. Anyway, how can I disable the soft close for that door again? The reason why I want to do this is to avoid burning my pump. Thank you in advance.
Warren, correct me if I'm wrong. In my car when I had a problem with soft close for the driver's door when I was unplugging and replugging the fuse I could hear a hissing sound from the driver's door for about 5 to 10 seconds and after two to three repetitions the soft closing stops working for the driver's door only untill i changed the lock which was broken from inside.Alternatively, you could pull the fuse and leave it out until you have made the repair. There is not a simple way to deactivate soft close for just one door.
To do that would require going into the door and disconnecting the vacuum lines, and plugging them. If you're going to do that, you may as well fix the leak.
