An update of sorts. I sourced a camshaft all sensor, and an air pump switchover valve but it seems that both of my current items are not in fact faulty as they've both tested OK (as far as following YouTube videos tells me that is!) so now I'm wary of what the fault codes are telling me.
The codes I have currently are: -
ECM - Engine Control Module(ME) 6 problems exist
1.P0340-001 No 'Cylinder 1' Recognition Of Component B6/1(Camshaft Hall Sensor).
2.P0443-002 Y58/1(Purge Control Valve): Possible Cause: Open Circuit Or Short Circuit To Ground
3.P0725-002 Engine Speed signal(TNA): Possible Cause: Open Circuit Or Short Circuit To Ground
4.P0410-002 Y32(Air Pump Switchover Valve), K17(Secondary Air Injection Relay): Possible Cause: Open Circuit Or Short Circuit To Ground
5.P0135-002 O2 Sensor Heater Of Component G3/2(O2 Sensor Upstream Of KAT): Possible Cause: Open Circuit Or Short Circuit To Ground
6.P0340-002 'Cylinder 1' Recognition Of Component B6/1(Camshaft Hall Sensor) Is Implausible.
I've got the WIS software, so I'm off to take a look around that to see if I can figure out the wiring for all these things and whether that are connected. Any pointers/hints/clues gratefully received
