Went in to smog check today and the darn check engine light came on during the test. I failed with flying colors. The smog check shop gave me a print out with the codes. I hope the Gurus on from the club can guide me and give me some pdf's to DIY.
They Tech at the shop mentioned sometimes a faulty O2 sensor can cause a domino effect of these codes to appear. I hope he's right, and all I need is an O2 sensor.
P0105 Map/Baro Ckt Malfunction
P0442 EVAP Ctrl System small leak detected (Brake booster leak maybe causing this)
P0400 EGR Flow Malfunction (DIY. cleaned the valve 3-4 months ago).
P0136 O2 Sensor Fault, Bank 1, sensor 2. (I have the DIY to this, already ordered the part)
Thanks in advance.
Thanks in advance.
