E320 2000
hi all
i have e320 yr 2000.. my problem is my smart key stucked in eis and not come out
the car switching on/ off normally but i cant remove key out. did any one had this problem
note this problem came after ABS ligh on and gear not lefting any relation between them.
thanks
E320 2000
Hi all
I sloved mine
It was from the transmission shifting sensor was miss plug . I pluged it back correctly then the key released .this sensor is under windows switchs board connected to shifting gear box
Glad you found it -
1) The brake light switch is always the 1st suspect, it is the primary interconnectsafety system. The original design brake light has been known to commonly fail over a reasonable period of time. Mercedes has just released a updated-updated brake light switch (looks the same but internals redesigned). When replacing the brake light switch ONLY buy the MB branded part the China knockoff's are horrible.
2) The transmission is the 2nd/parallel safety interconnect safety system to prevent the starter from engaging while the MB is in gear. In your case I am gratefull you found it was a failed connection - in other cases where this tranny interconnect fails it can be the internal switch/sensor inside the transmission shifter.
Very happy it all worked out - keep the beat !
