2008 CLK550
I tried to change out the battery on my SmartKey fob, which I have done before, but the "tray" inside would not come out, even using the manual's technique of depressing that thing inside with the mechanical key and pulling. I used more force and the chrome end thing came off. Im not sure what went wrong but it would not slide out like normal. I can't get to the battery.
So, what is the cheapest way to fix this? I found a shell of the same fob, how would I transfer the computer part into the new one? Would an auto locksmith help?
Office supplies Wood Lamp Writing implement Tints and shades
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Your batteries may have corroded and become stuck.
I would spray some WD-40 or similar into the battery area , wait a while and then try to carefully lever the battery holding section out using a table knife end.
Once you get it out you can figure out what needs to happen , if you can replace the batteries and perhaps re attach the end part with super glue ..
If not then yes , get help from a key auto locksmith.
2008 CLK550
I tried it but cannot get that center battery section out even with a swiss army knife or small screwdriver pulling it. Im going to try to cut it out once I get the new shell case to replace the ECB in. Key looks old, the buttons are already smashed in a bit.
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
If you can get the circuit board out without damaging it, you can put it into a "donor" key and use its housing and battery carrier.
