1 - 15 of 15 Posts
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
2011 SL550
http://www.benzworld.org/forums/r230-sl-class/2267810-instrument-cluster-inkblot.html
Search google for pink shrimp sl lcd panel. Fairly common.
I expect it is this...it can change, morph, but believe the long-term trend line is only one direction. I did find an 'expensive' instrument shop to replace mine, move the miles over (mine was on the speedometer). All was fine afterward. Ultimately I sold the car and bought a newer one.
SL65, SL600 RENNtech, 300D, LP640 & Panteras
Discussion Starter · #7 ·
Went to cruise the coast today and noticed upon start up that the mark grew larger even with the car just sitting there overnight not running. Ugh, may need to have it taken care of with it growing like a virus because now I really notice it. Will look into cost with my mechanic, as my skills may not be that great to do it on my own.
Here's another thread about this:
https://mbworld.org/forums/sl-class-r230/577200-sl500-2003-instrument-display-led-problem.html
A guy there disassembled his and replaced just the LCD panel with a used one from a "donor" cluster. I've had similar issues with our C240 where the LCD dims when it gets hot. I have found a few places selling replacement LCDs for the C240 for around $70, which is much better than $2K for a new cluster. Just a quick search and I found this:
LCD Display for Dashboard Mercedes Benz R and SL Class
So, someone is making these LCD panels. You may not be able to DIY, but maybe you can find a good indy willing to tackle it this way as opposed to replacing the entire cluster.
Discussion Starter · #10 ·
2003 Mercedes SL, 1964 Corvette StingRay Sport Coupe, 1992 Mercedes 300 SL, Porsche 911 Twin Turbo
When the "shrimp" moves around like that it makes me think that the display does not have any broken pixels and that this must be something else
If there where any broken pixels they would be constant and not change and walk around like on your car.
I would phone a Mercedes mechanic and ask about it and also send him send an email with the pictures so they can see what you are talking about
It's not the pixels themselves, but a bad electrical connection in the Mylar ribbon cable and where it attaches to the glass that sandwiches the liquid crystal. It's not something that can be fixed - you have to replace the LCD panel.
Discussion Starter · #13 ·
Thanks for the info, I will just leave it as is and live with it & just enjoy driving it. No big deal for me in keeping it as is, and probably not worth fixing it since these cars sell for pretty much nothing anyway. I just found it interesting to see it disappearing and wondered what was going on.
2003 SL55; 2008 S550
If you can find a donor instrument panel, you can swap the LCD fairly easily. I wrote a DIY for doing this. https://mbworld.org/forums/sl-class-r230/593796-r230-instrument-panel-lcd-diy.html
Problem is...most LCD panels are old and the fade with time. Eventually, we won't have any bright ones to use anymore :frown
Something similar happened on the W230 C-Class, but instead of erroneous pixels, it would totally fade when left out in the summer heat. There are replacement LCD panels available for the W203 for around $80. Originally, it was an Italian company making them, then the Chinese got into it. I would guess someone makes them for the W230. BTW, "pink shrimp" is also a problem on the SLK.
1 - 15 of 15 Posts
