1 - 18 of 18 Posts
1980 240D
When my enginge finally wears out, it's only got 179k now, so it will be a long time so don't get excited yet or ban me, but has anyone ever dropped a small block v-8 in a 123, like a 240D, seems it would be the ultimate sleeper. yikes!
1982 300D Turbo
Here ya go, its been done before
http://benzworld.org/forums/forums/thread-view.asp?tid=1192676&posts=14&hl=w123+v8
BADBENZ!!!!
http://badbenz.com/badbenz/
I have also seen a page where some guy put a ford 302 in a 240d. I couldnt find the page.
A
Guest
yeah. get a motor from an original AMG 123 Coupe if u can. V8 Power!!
2005 w203, 2013 Town & Country
I didnt think that any w123 came with a V8...a I6 yes...but a V8?
a chevy is easier than a ford because of the oil pan / pick up...
it would be a nice sleeper...theres plenty of work to do with that ... but it can / has been done...
Jake
1991 300 SE
A 123d is a good idea; the stock front suspension, designed for the heavy all iron diesel, should be able to accommodate the V8. You know, a European market M116 3.8 L – which should be available in your part of the world – just might do. I think it’s easier to go from diesel to gas rather than gas to diesel. You should keep the glow plug light in the dash, btw.
That's the main reason i chose a diesel car as my platform. Surprisingly very few 380's made it here, most of the V8's were 500's & 420'S. Still the search continues.......
Why would you make a point of leaving the glow plug light in the dash,... am i missing something?[xx(]
1991 300 SE
Storm. - 7/2/2005 6:48 PM
No reason, just thought it would be a good conversation starter allowing you to launch into a protracted dissertation as to the installation of a gas V8.
jdc1244a - 7/3/2005 11:52 PM
You what what in the what now?
Seriously though I get your point, but if I told people here I converted a perfectly good diesel into a petrol V8 I'd probably get shot LOL!!!
300TE 4-Matic 300GD
Hey, Storm.
Are you on some kind of vacation, or something? I thought your location was London.
Regards
Geir
NordStern - 7/3/2005 3:48 PM
Hey, Storm.
Regards
Geir
Due to the nature of my work i tend to travel alot, though i was mainly in london for the birth of my son (I just sceduled my meetings & training aroung it)
Vacation,....my life is a vacation, I'm a father[8D]
V8 W123
I'm in the process now of putting a (MB) 5.0L into a W123 coupe. It fits, it is tight, and it is alot lighter than the diesel that came out. The car sits on the front springs about 2 inches higher than it did before. There is a ton of things to do, mostly related to the wiring that simply was not required for the diesel.
Here is a partial list:
shortened drive shaft/custom exhaust/different suspension springs/tank fuel strainer for gas/mount & wire elec fuel pump/ fabricate box near battery for idle speed control/ customize battery tray/customize (hammer) radiator area to accept 500SEL radiator/ change cable for 80 amp alternator/change brake booster/fabricate heat shields over steering joint & passenger footwell/custom air conditioner lines/modify power steering lines/change trans tailcone to drive the mechanical speedometer/fabricate box for fuel pump relay/locate,run,shorten,lengthen 4,000,000 (+/-) wires/provide for direct feeding oil pressure line/...............
Good luck. It is a journey. It has been a great project though. I started in Feb, and figured it'd take a year. Haven't done much thru the summer as it's too hot, and my daughter goes off to college soon, and we still like to spend time together.
hi
might be easier to move battery to the trunk, thats what i have done....
good luck
jake
1 - 18 of 18 Posts
