Want to put S-03's in 225/40/18 front and 255/35/18 rear. The wheels I want come in 8' (s/b fine in front) and 10' -- but not 9'. Will I have a problem with the 10' in the rear wells? Is my offset still 35mm, front and rear? Has anyone tucked fatter rubber on 18's in the rear of the SLK32?<br> Thanks....
Discussion Starter #2
the 10' wide rear should work with either a 30mm or a 27mm offset. The only reason that it will work is the factory rolled fender lips and a more aggresive alignment setting. I would suggest a 9' wheel for easier fitment.<br> <br> Luke
