1 - 9 of 9 Posts
SLK32, ML430
This weekend was the largest gathering of AMG's in the country. We had 3 (or 4) SL65's, 3 SLK32's, an ML55, a C32, several E55's, and E55 wagon, an SL55, a couple of CLK55's, and a C55.
I will post pics, dyno graph, and more info when I have time.
Some info that many will be interested in.
1) The C55 put down 280hp. As a note about the low number it only had 3,000 miles.
2) The SLK32's were all very close in their numbers. I put down 298.5 hp and 292.6 ft/lbs of torque. If memory serves the SLK32 with the most miles (40k+) put down 294hp and 300 ft/lbs of torque. The other SLK put down 292hp and 288 ft/lbs of torque.
3) The E55's dynoed within 1hp of each other.
More info to follow.
Tomorrow is off to the drag strip.
2002 SLK 32 AMG
I'm not that much of a grear head to know this, but 430, where's the rest of the HP and torque that we're supposed to have? "Ju hcave somma esplaining to du Lucy"...
06 corvette coupe
John Boy 330xi - 5/1/2005 10:01 AM
those are rear wheel #'s. the manufacturer rates it at the flywheel. Usually 15% loss due to drivetrain friction is normal (maybe a little higher w/automatics). 290HP is about right for a 350HP engine.
2002 SLK32 AMG, 2006 CLS55 AMG
My SLK32 AMG dyno'ed at 296hp/292-torque, and it has 56,500 miles on the odometer (the other SLK's had less than 17k on them.[:)]
SLK32, ML430
Hopefully I will receive an email today containing the dyno runs from all 3 slk's or better yet the dyno runs of all the AMG's. I did take some photo's of the prinout from the dyno. I will look through and see if they are readable enough to post.
SLK32AMG
rbridges - 5/1/2005 10:45 AM
The AMG autos should be fairly close manuals. They have a lock-up in every gear.
1 - 9 of 9 Posts
