SLK230 1999
[:)]Had some problems lately with inside windows misting up on my SLK230 after standing.
Cleaned out the drain channels at either side of the rear window and took off the plastic trim panel covering the windscreen wiper mechanism to clean the scuttle drains. Found one front and one back drain blocked with leaf debris. Anyone else had this problem?.
SLK 230
Check the one inside the trunk under the spare tire.
Check your pump and trunk for water since you had 1 over the trunk that was blocked.
