Hello.
Anyone know how to reset this warning: "Main Inspection Performed on Time?" ?
I receive it anytime I enter the car.
There is no way to set to Zero like it was before.
I did a mistake confirming it.
Do I have to go to the Dealer?
Thank You
Regards
Discussion Starter #2
Nope...
I don't know how to switch username.. :)
1. key in pos. 1
2. press reset button 3x quick
3. display shows battery
4. with the arrow down to service menue
5. press 3x "-" (minus) until confirmation appears
6. with the arrow one position down to the next menue
7. you should see "confirm", "delete" and "delete mistake" now
8. change to pos. 2 now
9. press "page down" while "confirm full service" appears
10. you get a confirmation
11. press "back" to go to the standard menue
Hope my translation helps you. If not, here in German language:
1. Zündschlüssel in Pos. 1
2. Reset Button 3x schnell hintereinander drücken
3. Display zeigt Batterie Spannung
4. mit dem Pfeil nach unten auf Service Menü
5. 3x "-" (Minus) drücken bis Bestätigung erscheint
6. mit dem Pfeil eine Position nach unten auf das nächste Menü
7. Nun sollte "Bestätige", "Lösche" und "Lösche Fehler" ersichtlich sein
8. auf Pos. 2 wechseln
9. drücke "Seite unten" während "bestätige Full service" erscheint
10. du erhälst eine Bestätigung
11. drücke "zurück" um wieder ins normale Menü umzuschalten
Thank You.
I'll try as soon as stop raining. :)
2 more questions?
1. key in pos. 1
I recently did a tune up on the same car , and the exact problem happened to me , I followed your instructions but I still have a question after # 7 should I put the swicth on 2 then press page down , or should I maintain my finger presing on page down so it will clear and give me the confirm? help plz, I have done both ways and it still says that it is not confirm.:confused::confused:
