The SLK 280 2008 has transmission with 7 positions and Comfort (automatic) and Standard, Shiftier can not go after Neutral position. On D position transmission perfectly change at C or S. Since shiftier is stock in N I can not remove the key. With no parking position able no key removal possibility. With only 36 k miles. no brake switch problems and no transmission code i do not know what to do. I removed the gear shiftier and there is not apparent mechanical problems. the gear box has screws and glue sealing it. Please let me know about possible problems and solutions
Moderator: thanks for your reply, Keys can not be removed because gear shiftier does not move to Reverse and Parking. See post information
Probably it is in limb mode. Shiftier does not have mechanical problem. The control panel showed me a ntake light. I did not yake care because I was concentrated in the gear box. An reference stays that even a brake light may cause limb mode. If is true how ridiculus are MB Engeneers.
