SLK 230 R170 No Start No Crank Problem Fix
15K views 5 replies 5 participants last post by  chava
Hi I have recently had a 'No Start No Crank' problem with my SLK 230 R170. This happens when the key is turned on and all the dashboard lights show but the engine will not turn over. I did some research on this problem and it appears that this is a common fault with this model and there is a simple fix which can be found on You Tube
Hope this is of interest.
Dglad
